Old 07-27-2023, 02:22 PM
UPDATE: I was able to locate my DMM and I was able to confirm tha those resistors were indeed around 75K ohms so like I said I'm guessing that is way above the 10% tolerance the resistors are rated for so I'll need to replace those for sure.
So according to my calculations the resistors are just barely outside of the 10% tolerance range, 74,800 Ohms and under is within the 10% tolerance range of the 68K Ohm resistors and the resistors were measuring 75,300 Ohms...
Which is probably the reason why those resistors haven't cooked themselves yet and also probably the reason why the transistors may not of fried yet, but are still affecting the picture quality, but also I haven't ran the TV for more than a few minutes at a time to do some troubleshooting and shutting it off in between.
