Old 05-27-2023, 09:44 PM
Lain94's Avatar
Lain94 Lain94 is offline
Another thing to try for replacing a non-polar electrolytic cap is to get two polar caps, then wire them in series with opposite polarity. However, this may be a problem in high-current applications like the convergence circuit. Better to be safe and get an actual non-polar replacement.
What value and rating is this cap?
The capacitor has a rating of 30uf and 25VNP with a tolerance of 20%.
Removed it already to test, and while the ESR was ok, I then used a simple capacitance meter that runs on a 9V battery. It measured the capacitance as being WAY out of spec like a bit over 300uf! Yikes!
Definitely bad.
