Old 04-28-2023, 04:10 PM
No, it's not a run change. That cap needs to be there. I suspect you just found the problem.
Yes I found it but I still looking for the reason why if I use vertical size to widen the screen up and down sometimes it goes and other times it don’t but it’s got vertical lines on the bottom and some on top but very unstable it rolls but it does stop with the hold pot this almost seems to be a bad cap or wrong cap I don’t know. The .004 cap was replaced with a .0047 I wouldn’t have put that in since the .004 is available. Oh and I reversed the 1n34 diode and got a perfect picture except for the lines and instability in vertical. I thought I had a decent picture befor I reversed the diode but now it’s perfect now have to figure what’s going on with vertical.
Old 04-28-2023, 05:36 PM
Chris K Chris K is offline
The detector diode is a strange trip. In the TS-4H schematic I have it was installed correctly. I had it in the direction you now have it but reversed it when I saw the schematic. The original 1N34 was installed the way u now have the replacement wired so IDK…these TVs have a lot of variability
Old 04-28-2023, 05:46 PM
The original was put in the opposite of the way the schematic shows? That’s how I have it now and the b+ voltages came up good.
