Old 04-25-2023, 03:40 PM
Originally Posted by Chris K View Post
Looking at Bobs schematic for the ballast and pictures of what I built I made a single change. The thermistor was installed between pin 5 (due to the pin switch for this chassis) and the intersection solder point at the top for the resistors. I did this because my chassis had the older version of the ballast installed originally and that made the pin setup different… a switch from pin 6 to pin 5 for one side of the AC line. Maybe I made a mistake somewhere? I don’t remember it getting to the realm of too hot to touch but I’ve made so many errors on this tv it’s hard to imagine what state of mind I was in when I did it!
Even after about 5-7 minutes checking voltages you cannot touch it it’s hot but I feel the voltages are in the right area. If a mistake was made on the ballast then there should be several discrepancies in the voltages. So if later on I find that there is infact a problem with the ballast I’ll just put one together with resistors.
