  #38
Old 01-17-2023, 07:12 PM
LukeSimon LukeSimon is offline
Another observation when swapping in NOS tubes, I replaced tube V5, which is used as an amplifier that also separates luma, chroma, and sync signals. The tube has a grounded shield. The chassis originally uses a 6LM8, but I replaced it with a 6LM8A. As you can see from the picture, the 6LM8A is the tube on the right. Its plate has twice the surface area of the tube on the left, and it has a black plate (for a higher max wattage rating).
The 6LM8A tube works as a substitute in the TV, but the colors streak badly. This is likely due to a much higher parasitic capacitance between the tube’s plate and the tube shield.
File Type: jpg 154F9EF9-EBE4-4C39-9D93-7DEA358EDEC9.jpg (98.9 KB, 71 views)
