May want to use a sound capable signal source to check sound circuits are functioning properly.
Also not really important but this set can directly accept 300 or 75ohm antenna hookups. The outer screws are for 300 and IIRC the top screw and center G terminal are used for 75 ohm center and shield respectively. (I may have too and bottom mixed up, check literature before using the 75 ohm direct connection.) Not really that important, but interesting.
