Old 12-06-2022, 10:45 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Hi Dave,
If it takes so long until the set works, I should search for a bad tube.
If the set is completly recapped, the next step will be troubleshooting for
a bad resistor.
Measure the right voltages to control the horizontal stage when the set is just
switched on.
Than check again after 20 minutes.
This could guide you!
Good luck!
Regards,
TV-collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany!
