Old 12-01-2022, 04:06 PM
The 2 letters in the chassis number were model year M and the color TV chassis designator C. The first digits are tube count and the last were feature level. I've had both a 25MC33 plain Jane console and a 25MC43 remote set and the main difference was addition of the socket and wiring for the remote reciever chassis and the motors on the tuner and tint pot.
Zenith had 5 chassis years of color roundys the J, K, L, M and N year chassis.
The 24MC chassis you have has 1 less tube it could be a cost saving measure or a case of engineering trying a SS part and needing 1 less tube. It should be the same year as the other set you have.
The linearity coil forms can be brittle and or melted treat them with care...Zenith's don't eat flybacks like RCAs so I typically don't tweak output current unless it's fairly out to lunch. Even into the rectangular era Zenith's have been noted to have vertical transformer failures.... I've been lucky enough to not experience it yet (knock on wood) having at least 9 different tube color Zenith's come through my hands.
Old 12-02-2022, 12:29 PM
trinescope trinescope is offline
The Zenith vertical output transformers have a habit of developing shorts between the primary and one of the convergence windings, which essentially shorts the vertical stage B+ to ground through all the low resistance parts in the convergence circuits. For whatever reason the insulation on the wires as well as the paper tape materials break down. I had this failure on a CTC-5 as well, due to the way the windings were done it allowed all four secondaries to short to B+, which smoked all three DC convergence adjustment pots. I have already rewound that transformer, and is working, just need to find a working substitute for the three pots (100 ohm with a tap at 75%).
Erich Loepke
Old 12-02-2022, 01:38 PM
I am amazed Zenith color TVs even had this problem (shorts in the vertical output transformer) in the first place. I would have thought Zenith's quality control department would have been aware of this and corrected the problem long before it reached this point. Zenith, after all, was one of America's best radio and TV makes (if not the best, hands down) since the company's founding in 1918. Why they would allow defective components such as vertical output transformers knowingly get into their televisions (unless it was a one-time fluke) is beyond me. I always thought their QC (quality control) division would have caught this problem before it became anywhere near this serious. If Zenith were not already as well-known a company as it was, I would think a problem like this would have put the heck of a dent in its reputation. Zenith's decades-old slogan, after all, was "the quality goes in before the name goes on"; a problem like this would have all but ruined the integrity of that slogan (and put the company out of business for good) in no time flat.
Old 12-02-2022, 03:28 PM
Zenith VOT's are known to go BUT ....
I worked from 1970 on at one of the biggest Boston area Zenith dealers.
I was also jig man so I would have repaired most VOT jobs on big sets.
In all those years I may have replaced 4 ? of them all the way up to hybrids.
I put more in 9" & 12" Panasonic B&W's, so many we stocked them.
This seems to be an age related problem not overall mileage.
As far as QC goes I dont remember who built them. If someone can look
at one & get the EIA number that will tell who. Dont forget also TV's
were NOT supposed to last 50 yrs. If VOTs are popping 5 yrs down the line
QC probably isnt to blame.
BTW I have the price / substitute guide form @1977 & can check for subs etc.
Old 12-02-2022, 04:13 PM
So far every vintage style transformer I have unwound has been constructed of the same materials; enameled magnet wire, some sort of thin, wax coated paper between winding layers, and kraft paper covering the outside of the winding assembly. It's the wax paper layers that get burnt through, creating a carbon path and a winding short when the enamel on the wire fails after age and there is enough voltage stress to cause an arc. Voltage pulses in the vertical output stage can reach up to 2KV or so. Modern single build magnet wire insulation is good for 700V, and Kapton tape for 7KV/mil; these are what I have used so far in my transformer rewind projects. I'm sure Zenith had a few failures at most when the sets were current, these failures are occuring decades after most of these sets were retired by their original owners.
Erich Loepke
