Old 10-14-2022, 10:43 AM
brodek brodek is offline
I wanted to follow up with what I think is the final fix for this issue on this set. I was not able to "clear" the fault using freeze spray on the micro. So oddly it didn't seem to be temperature related. It did seem to be power on time related. When the set is plugged in I would see the voltage drop after a period of time causing the fault condition. I had already removed the two "debounce" caps so they were eliminated as a possible cause. I then went back and did a much better job of cleaning up around the micro pins and these caps. After doing that the fault was cleared permanently. So either I had some tin whisker growth that I couldn't see with the naked eye or some type of dendritic growth that took some extra cleaning to clear completely. It's been a few months and the set is still working perfectly. Glad to have the old girl working again.
