Old 09-30-2022, 04:01 PM
this makes no sense... is was OK before, your last post stated " make a new couplet k1" was that done?
if so, it clearly upset something, try putting it back the way it was before.
No I didn’t make the couplet until I get resistors I only had the 680k the others are so so but in trying to set the -45 I noticed I can’t get it to -45 and the screen is dim at 22kv and with the meter on number 5 of the hot my meter is showing 1.3 amps on the ac scale but I had it set to dc but I know this meter if there is excess current it shows on the top scale and you are right none of this makes sense but I will tell you that I had to adjust the horizontal coil to get the oscillator going initially after getting a better signal to the IF but I took to look and the hot both turned red so I don’t know if I damaged the flyback because of that I don’t know and I’m preparing put the original flyback back in because I don’t trust the new one this maybe affecting the agc and the IF.
