If you're sitting more than 3' away from the set even if the X ray leak is pointed at you it probably will be unmeasurable. Air attenuates X rays.
You could also put some small holes at the top and bottom of the cage and blow in the bottom of suck out of the top with a small fan. I typically on transformer powered sets rectify the heater to get 6V DC and use that to power a small 12V computer fan at half speed for quiet.
