If you are sure that the problem is the CRT and you think you can find a replacement tube, I suppose as a last resort they are OK.
There have been cases where a previous person put a brightner on because they didn't correct the real problem with the set. Brightners age the gun cathodes faster than normal so whatever life is left in the CRT is used up fast. The proper use for them was so that a TV owner could have a brighter image while the repair shop was waiting for a replacement CRT to arrive. Today replacement CRTs are much harder to find. Typically on a color tube one gun wears out first making the color balance impossible to achieve. If you say all the drive controls are set near one end it suggests there is another problem that is common to all colors. |
