Old 08-17-2022, 03:33 PM
The voltages are somewhat low because the chassis is out and no tuner plugged in. I had picked up lindal tubes and they say they are no good so I have 2 more coming so maybe these tubes are no good since I had 2 others that didn’t move the needle on the tester and yet I had sound. X6 is almost impossible to reach but I did a test these Germanium diodes are so sensitive that testing each end causes the numbers on the meter to jump back and forth and that’s what the diode in the set did exactly with the diode I have in hand did the same so I’m assuming it’s good and from one end of the diode to pin 7 has continuity. Voltages on 6w8a are there but 7 I think was not 5 volts more like 12 volts but no tuner plugged in.the other part to this is channel 3 may be way off as far as tuned don’t know the history so took out the tuner and the slug for channel 3 was all the way in I don’t know if it’s usually in or out more then in so I ran it out and sprayed the gears the grease gummed up wasn’t really working now it is so I’ll find out tomorrow what happens.
