Old 07-25-2022, 09:25 PM
Lain94's Avatar
Lain94 Lain94 is offline
Welp, an update on this tv, after going through the capacitors and inspecting the tv and getting it turned on. The 6KD6 Horizontal output in the tv started arcing like crazy within seconds of power being applied. I quickly turned the tv off. I am guessing that tube is bad. And of course naturally it is the most expensive to replace tube in the set I later discovered when searching ebay. Also the thermistor attached to the degaussing coil is burnt looking and had no continuity which explains why the degaussing coil was disconnected from the tv by someone at some point.
