Old 03-07-2022, 03:31 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
What's the tape path look like at the guide just after the AC head? I've seen the vertical forward-back tilt or "zenith" of the AC head. or a worn pinch roller, cause tape skew.
If you go messing with the entry and exit rollers you will probably need an oscilloscope hooked to the head amp RF-out to do an alignment assuming you have a known good tape. Put a small mark with a felt tipped marker on the shiny metal part on top of each roller assy just in case, so you can put them back where they were.
