Old 01-15-2022, 05:14 PM
Jon1967us Jon1967us is offline
Here's the Sam's
https://drive.google.com/file/d/1Bpq...ew?usp=sharing
Old 01-15-2022, 05:59 PM
Start with the blank white screen. Most likely IF problem. Now we
use the built in signal ( noise) injector........
Turn channels. If you see & hear crashes of the tuner switches its the tuner.
If you dont then its IF problem.
You can do the same with the IF. While running take out then put the
IF tubes back in. Watch for crashes as above. 1 IF, 2 IF, 3 IF its a chain.
The pix with retrace has color info but not video. Trace the video amps & out.
Nice sets, I had one in the maple flavored cabinet back 30 yrs ago. Great sound.
BTW go easy on any coils. Flag your tool so you can go back. Also do not trust tube checkers.
Old 01-16-2022, 10:49 AM
The 3rd picture from the top shows the set having lost the luma (video) signal, with the chroma signal still present. The two most frequent causes are:
1. Dirty service switch. Try working the service switch and giving it a shot of Deoxit or similar.
2. Heater-cathode short in the CRT. Try rapping on the neck (not too hard) while watching the screen with a mirror.
