Reread post #245 where you had 210v at C3B. You need to follow that point to pins 5 and 6 of your 6AQ5 and see where you loose the 210V. Follow the schematic and ohm everything out. One path is from C3B positive to pin 6(screen), the other is C3B positive to the bottom(red) wire of the output transformer primary. B+ needs to go in on the red wire of the primary winding and exit on the blue wire to pin 5(plate) of the 6AQ5. If there's no connections where there should be, something has become open or otherwise mis-wired. Quote:
I really don't know what's going here. |
Ok, I wondered about that. I'll get you a picture of my 5 (6)AQ5 tube section of the TV and the replacement electrolytics.
Bought and sold a set like that about 60 years ago. Mine was an earlier model that used a 3BY6 instead of the better circuit using a 3BU8. The outward appearance was similar. |
) soldering iron I'm able to heat the ground lugs and squeeze them straight with a flat nose pliers, then carefully wiggle them free. Space permitting you certainly could hack them off using a Zona saw while they're still attached to a chassis.
