Old 09-27-2021, 07:37 AM
DavGoodlin's Avatar
Motorola Minion
The Funai built convertors aren't as sensitive as the Zenith/Insignia units, but are more reliable. You need a real good signal. I use either Zenith/Insignia or Digital Stream. The same thing goes wrong with the Zenith/Insignia boxes, the 1000mfd 16volt capacitor in the power supply board. When repairing, that's the only one I change!
Thanks! I was wondering if I need to do all of them eventually or that I missed a surface-mounted electrolytic.
The Funai get local RF (those not my DX choice either) and their best feature: when they lose power momentarily, it does not turn them off.
The Channel Master CM-7000s quit long ago, by far the best for storing channels as you rotate you antenna, but once scanned - virtual and rf numbers get duplicated and direct access tuning of RF is lost.
-Dave G
