Old 05-30-2021, 08:58 PM
ESigma25 ESigma25 is offline
1979 Zenith "Video Director" Beta VCR Doesn't Play
I got this enormous Zenith "Video Director" Beta VCR from 1979, model number is VR9000W. It threads tapes really well and the belts are in good shape but for some reason it just will not play. It will make kind of a solenoid click sound and push out a tape guide but then immediately click again and move the tape guide back in, and I don't know why. Could it be a dirty mechanical sensor inside, maybe?
Here's some pics of the unit:
https://i.imgur.com/nbTCQY9.jpg
https://i.imgur.com/UDMT3W6.jpg
https://i.imgur.com/vEvYOgv.jpg
https://i.imgur.com/aJHJPoT.jpg
Old 05-31-2021, 12:31 AM
Make sure you're capstan motor isn't stuck. IIRC it was on mine, but when I did mine I also repaired the Sony badged version, a front load Zenith beta and an older top loading Zenith beta so I could be smearing the memories of 5 consecutive repair jobs together...
Old 05-31-2021, 11:11 AM
Hmm, it is possible a motor is stuck. Capstan motor being stuck would explain why the tape threads but refuses to play/rewind/fast forward.
Old 06-02-2021, 06:25 PM
Verified nothing is stuck, sprayed down the mechanical switches on the board with contact cleaner, and it still has the same behavior as before. Pressing Play causes a solenoid to engage and push out a tape guide but then said solenoid immediately disengages and the head drum stops turning.
I also notice that trying to play causes the tape to become noticeably less taught, as if the supply reel is supplying more tape but the take-up reel is not taking it up, in addition to the other not playing symptoms.
