Hi to all,
True 525/60 to 625/50 & vice-versa conversion exists at consumer-accessible prices. Good ones sample Y at 13.5 MHz & R-Y/B-Y at 6.75 MHZ. True digital Frame Store (2MB to 6MB or more) with movement interpolation. Work as a TBC, useful for VCR tape copy. Some high-end models have GenLock for studio/editing needs. I use a bunch of these, notably to Tx OTA genuine NTSC USA from 625 sources. These are technical wonders. In the late 60s, was a roomful of equipment with 100's of KW power consumption and, oh yeah multimillion $ cost. look up the IBA's DICE (Digital Intercontinental Conversion Equipment) see the monster here, a Marconi 4 page pdf : http://marconiintelevision.pbworks.c...0Converter.pdf Some example of modern consumer converters here from this French supplier : https://www.goyona.com/VIDEOSYSTEMhtm.htm#CDM660 And a US supplier : https://www.220-electronics.com/pal-...converter.html Cheapo units decode the color subcarrier & re-encode to the wanted standard without modifying line/field rate. Works OK. I designed & built one from scratch circa 1985 to use a Panasonic CT-101 1.5" micro-CRT color TV, converted PAL/SECAM to NTSC USA. Addendum : heavy stuff, BBC research pdf's on standards conversion : 1964, early work on B&W standards conversion: http://downloads.bbc.co.uk/rd/pubs/a...nograph_55.pdf and Colour, later, 1972 : http://downloads.bbc.co.uk/rd/pubs/reports/1972-22.pdf Best Regards jhalphen Last edited by jhalphen; 04-30-2021 at 01:09 PM. |
