Originally Posted by ppppenguin
I don't think either of those conversion methods has ever been used. I suspect the cheap boxes simply do a PAL to NTSC transcode, leaving the frame and line rate well alone.
In PAL countries some VHS machines would play NTSC tapes at 525/60, transcoding the NTSC to PAL. This would work on most TVs at the time as the H scan rates are almost identical (15625 vs 15734Hz) and the V scan rates are close enough for most sets to lock. Though sometimes with reduced height.
There was also NTSC 4.43 which was used on mainly Middle Eastern machines as a workaround, i think this - apart from the speed and frame rate change to 525/60 - shifted the NTSC colour carrier from 3.58 to 4.43 to match the PAL colour carrier frequency.
As previously stated PAL 60 was a workaround to allow compatibility of NTSC tapes and DVDs with existing TVs. I remember i had a late 80s PAL only Philips portable TV. My DVD player at the time a Pioneer, could be switched to PAL60 and the resultant Region 1 DVD image was excellent.
Today virtually all European TVs can cope with every legacy standard via input (sometimes even via analogue - I have a Sony TV that has an NTSC-M tuner built in), I suspect that this is harder in the US where most Mainstream TVs are hard wired for NTSC/ATSC only. I am sure I will be corrected!
