It is conceivable to have a VHS player that slows the PAL tape down to 24 frames per second, then throws away one scan line out of every six, then does 3/2 pull down. This would give the correct audio pitch.
It is also conceivable to have a VHS player that runs at PAL rate of 25 frames per second, then throws away one scan line out of every six, then duplicates every fifth frame to get 30 frames per second. This would not correct the pitch, and would result in a motion jump five times per second. Either of these processes requires an analog to digital conversion and back to analog to make the output be a continuous NTSC signal that an NTSC receiver can use. The picture content, however, has either 3/2 pulldown or 5 Hz motion jump. I see some really cheap (under $15) converters advertised, and since they are not built into the PAL source and can't slow down the tape playback, I guess they must use the second method; but I don't really know what's in them. |
I don't think either of those conversion methods has ever been used. I suspect the cheap boxes simply do a PAL to NTSC transcode, leaving the frame and line rate well alone.
In PAL countries some VHS machines would play NTSC tapes at 525/60, transcoding the NTSC to PAL. This would work on most TVs at the time as the H scan rates are almost identical (15625 vs 15734Hz) and the V scan rates are close enough for most sets to lock. Though sometimes with reduced height. |
As previously stated PAL 60 was a workaround to allow compatibility of NTSC tapes and DVDs with existing TVs. I remember i had a late 80s PAL only Philips portable TV. My DVD player at the time a Pioneer, could be switched to PAL60 and the resultant Region 1 DVD image was excellent. Today virtually all European TVs can cope with every legacy standard via input (sometimes even via analogue - I have a Sony TV that has an NTSC-M tuner built in), I suspect that this is harder in the US where most Mainstream TVs are hard wired for NTSC/ATSC only. I am sure I will be corrected! |
Im curious why my PAL-NTSC tape of SONG OF THE SOUTH is fine,no speedup at all.. (Unless they did it correct on the PAL tape) And I have a Phil Collins concert (1990) - Seriously live that someone told me was originally PAL and it was just converted to NTSC for NTSC areas.. No speedup on that either and video is goregous! (Original analogue concert audio on the linear track) Best sounding songs I have heard from him -- Over 2HRS of his best 80s music! |
