Old 04-09-2021, 08:41 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
An Admiral followed me home today......
A 60s vintage B&W portable 17” Admiral to be exact. $25 on Craigslist and it works! Not sure what model/chassis but that will come later when I pull the back off......
Old 04-09-2021, 08:57 PM
It has UHF, so it has to be 1964 or newer. I would say mid-60's.
Old 04-09-2021, 11:12 PM
mr_rye89's Avatar
Still not sure about the chassis number, but definitely past 1964, we have UHF and compactrons. Dirty filthy needs a clean and a recap but not immediately. All tubes are Admiral so it might be a low-ish hour set
File Type: jpg 13AF3A7C-4084-4CB2-A19C-67A2D7611F28.jpg (132.5 KB, 60 views)
File Type: jpg A47AFA3A-49B8-4687-871A-AC401B47599B.jpg (92.3 KB, 37 views)
File Type: jpg 39168BA5-DE52-4DC2-9061-2A6282F00F38.jpg (139.3 KB, 40 views)
Old 04-09-2021, 11:14 PM
mr_rye89's Avatar
Chassis/model #
File Type: jpg 6EBA8ACD-41E0-4DA5-8C36-711DF6F19BC3.jpg (69.7 KB, 31 views)
Old 04-11-2021, 11:27 AM
That was a good performing set, considering it has only two stages of IF.
It has keyed AGC, that's why! It doesn't show a HV rectifier tube. It must use that strange campactron type that only has two pins.
Old 04-11-2021, 07:06 PM
This was the last of the good mid priced Admiral B&W sets.
After that the were basically better GE's all based on the same
compactrons. When they went SS they were a solid set. Sadly
after a few yrs of building good sets again Rockwell killed them off.
Old 04-11-2021, 11:40 PM
mr_rye89's Avatar
Yeah this is a great little set. I peeked in the HV cage briefly, looks like a regular 9 pin HV rectifier to me. I blew all the crud out of it, most capacitors looked like polystyrene types, but it had the white tubular type which are bombs lol
We’ll get a recap in at some point, I got too much taken apart at the moment.....
File Type: jpg 616F1313-A729-4CA9-9D76-53643FCD42CE.jpg (94.5 KB, 49 views)
Old 04-12-2021, 09:13 PM
nasadowsk's Avatar
Damn does run fast…
Did anyone reputable ever make a tube TV with just one IF stage?
Two stages seemed to be common, even on cheap color sets (CTC-20!). Did tubes get that good, or did set makers get that cheap?
Old 04-13-2021, 12:27 AM
I think Muntz had a 1 stage video IF portable in the late 50s early 60s...In their case it was cheapness, but in late 60s sets fewer IFs were typically because better gain tubes were being used.
Old 04-13-2021, 10:15 AM
Tom9589 Tom9589 is offline
I don't think I have ever seen a tube layout diagram which didn't show the HV rectifier. If one looks closely at this tube layout diagram, it looks like the idea for this diagram is to show how the series heaters are wired and since the HV rectifier is not a part of the filament string, it was not shown.
Old 04-13-2021, 10:35 AM
I remember seeing an Olympic with one IF stage, (6EJ7). I saw it in a early 60's Supreme manual. The strange thing was, the set had a full power transformer and 5U4.
Old 04-13-2021, 10:38 AM
Seems like the challenge of designing an IF strip was to get the required bandwidth, which required stagger-tuning of stages, which required sufficient gain per tube. With development of frame grid tubes (6EH7, 6EJ7 etc), the 2-stage layout became the limit of practicality.
Old 04-13-2021, 10:42 AM
It must be a slightly later model the used that crazy HV rect.
Old 04-13-2021, 10:49 AM
Wonder if the Mixer and IF had extra-high B+ on them or something
Old 04-13-2021, 11:41 AM
nasadowsk's Avatar
Damn does run fast…
That silly HV tube - 1AY2?
