Frankly I think doing a TV alignment is biting of more than you can chew at this point. Alignment is just about the most difficult thing to do if you don't have a thorough understanding of how a TV works and the test equipment.
The fact that you are using the wrong terminology is a bad sign. "Traps" are set to eliminate certain frequencies, like the sound carrier getting into the video signal to the CRT. "Filter coils or transformers" are tuned to allow frequencies to pass through the circuit. When the instructions talk about "peaking" it means adjust to get the most signal. The instructions have the meter connected to the demodulated IF signal (44.5 MHz for instance), you cannot measure the IF directly with the meter because the frequency is too high. It seems you are not getting the 44.5 MHz through the circuit if you are saying you are not getting a reading. Looks like you scope is a RCA WO-33A, I happen to have one of those. Your picture is not sharp enough to tell the model number otherwise of the test equipment. At best that scope is only good to about 5.5 MHz, so it cannot give you a good view of a frequency as high as 44 MHz. That scope has some goofy things about it like the frequency range is less when set for higher voltage sensitivity. RCA made some oddball test equipment that were different from the common test equipment. RCA was a big cheese in the radio business because David Sarnoff bought out all radio patents in the early days, so they thought they had the best ideas. The RCA sweep generator should work well with that scope however. You have to know your test equipment is working right however. |
