Every AKB problem I have seen ( many) was a weak CRT. On
older sets this caused blinking that slows with warm up. When it does its obvious the CRT is weak. It did not cause shutdown. One thing may be a H-K short. If it runs a while try lightly tapping the CRT neck & see if it craps out. This was on older sets. The other thing is the power supply. Not sure what yours has but the wide screen ( 30" & 34" ) sets had 2 IC's that constantly go. They caused all kinds of problems related to dead set, int start, shut down, hard start. More on that if needed. I had one & got sick of changing them every year. Other than that they were probably the BEST CRT TV ever made. 73 Zeno ![]() LFOD ! |
Sony Trinitron Fan |
I think I also solved what I believe was an intermittent heater cathode short issue last week. What I did was measure heater voltage and current, disconnect the socket heater terminals from the PCB and connected a small 6V relay that draws less current than the 6.3V 450ma heater and used that relay to switch on and off a new floating heater power supply I built from a 120V to 12V stepdown transformer a bridge rectifier and a LM317 regulator circuit (configured to output 6.3V). I also connected the heater to ground through a 1M resistor and .05uF cap to bleed charge down and ground any AC noise. Before this the set would have grayscale disturbance followed by it going red screen (with retrace lines) and triggering an automatic shutdown....in the week since it has only had 1-2 grayscale disturbances that have fixed themselves.
Tom C. Zenith: The quality stays in EVEN after the name falls off! What I want. --> http://www.videokarma.org/showpost.p...62&postcount=4 Last edited by Electronic M; 03-09-2021 at 10:34 PM. |
