Relay may not be for ON/OFF but degausing. They act different.
Yes its worth nothing but if you like it & it ran good give it a whirl. My memory is bad after the 80's & my duties changed so take this with a grain of salt. 1) there is a small 'litic cap in front of the FBT. Caused video problems. 2) In the primary of power supply there are 2 small 'lytics that kill the set. 3) pull both boards & go over them for cold joints real good. You will find some. Hopefuly one is the problem. The set is in Sams 2921. I will see if I got it. Beyond the above you will need it. DO NOT buy it from Sams. Too much $$ for a crappy PDF or Xerox copy you cant read. 73 Zeno ![]() LFOD ! |
