These *all* developed ringlets around the pins. Every Single One. If you resolder the IC and it's still no joy, you need to replace the LA7838, the 100uf cap, the 220uf cap, and a good chance the low ohm (like 1 ohm) from the 24V source off pin 2 of the flyback that feeds the vertical output circuit. If the 1 ohm is burned, check the diode connected to it and make sure it's not shorted. John Last edited by JohnCT; 12-12-2020 at 05:52 PM. |
