If the radio uses a 35Z5 there's a 6V dial lamp tap on it's heater. There probably a resis something like 20 ohms across the half the heater. If you disconnect the dummy load resistor and substitute a dial lamp across it and mount the lamp so it shines through the wheel but doesn't melt it you can have your dial lamp.
