Old 08-31-2020, 10:00 AM
Yes, I see that now, I just found a site that shows that they can be removed for cleaning.
https://www.rfcafe.com/references/po...march-1967.htm
This is my first time ever trying to clean this type of tuner, have seen mostly rotary switch type before.
Though the contacts ARE dirty and black in this tuner, I'm still not sure what is going on with the front end, by video injection, I have proven that all after video detector diode is OK and stable but tuner input is intermittent, which may or may not be due to contacts or dirty tube pins, (new clean tubes on the way) , or, it could also be out of tol resistors in the tuner/IF/AFC area.
Not really sure at this point, will have to see how it behaves with known good clean tubes in and cleaned sockets.
How it is behaving is a bit unusual something I have not seen before anyway, when the front end works, it works rather well, stable and solid for quite some time, but when it acts up, the screen goes to a blank raster, but only if it's being fed a signal on a given channel (rf mod into 3) , if I change away from chan 3, or shut off the rf modulator, the screen goes to snow, and back to raster when turned back on.
AGC problem? Noise cancel error? Flaky video detector? Or just a weird symptom contact problems perhaps?
