Unless you got it for dirt cheap return it. If you paid for a working deck you should get a working deck.
Well, it was about $95 on eBay. A little pricey, but at least it wasn't a grail VCR. I think I'm going to return it. I was expecting to have a nice, high-end VCR.
I think that's one of the JVC models from the mid-late 80s that would have intermittent mechanism malfunction due to a screw on the bottom deck board that would come un-grounded from the board. That screw (actually 3 screws see pic) grounds the circuit board to the chassis. A simple star washer under the screw and tighten 'er down would usually fix it. A shot of Deoxit in the mode switch and work the mechanism with a tape shell "dummy tape" too, but you kinda need to know what you're doing.
Might try and work a deal with the seller to get a part refund if you have someone local that still knows how to properly repair a VCR. Last edited by Ed in Tx; 08-27-2020 at 05:52 PM. |
