There's a few ways to knock it down if you decide you want or need to. If you have a variac you could plug that in either before or after the isolation transformer and use that to dial the voltage. If the transformer is beefy you could plug in some 60W or higher incandescent/halogen bulbs to it's output to try and load it down.
If you have a 120V to 12V step-down transformer you could wire that as a bucking transformer... basically connect one 12V lead to one 120V lead, connect a plug across the 120V leads and connect an outlet to the 12V lead that isn't connected, and the 120V lead that isn't connected to the 12V winding...you may have to swap the 12V wires to achieve bucking (it will either buck line voltage 12V or boost it 12V depending on how you connect it). Google line buck boost transformer circuit to see a schematic before you wire it.
