Old 07-22-2020, 03:47 PM
The linearity and height generally interact to a greater or lesser extent depending on the design, so trying to say it's one or the other may not help diagnose it. It's a vertical sweep problem, so you need to check components in that section whether they are attached directly to one control or the other.
Any resistor connected to the vertical tubes could be causing the issues the same as the ones on the height and Lin pots. The nice thing about working off a Sam's schematic is that the components for each stage are grouped together with signal in out and power connections marked so on any given stage you can easily say "it's gotta be in this cluster of 6-30 components".
