Old 07-20-2020, 01:30 PM
Which cap did you change capacitance on and did you measure and replace off tolerance resistors yet?
Paper/film caps should not deviate from the original design values (except in cases where the original is an NLA value like .05 and you have to use the closest modern value, in my example .047).
Before you try the absolute desperation move of changing film cap values you need to measure the resistance of every resistor in the vertical circuit (Google "resistor color code" explanation of how to read value) and change resistors outside of tolerance. Tolerance is the 4th band and will be %20 for no band, %10 for silver, and %5 for gold. So for a 100 ohm %10 resistor it is bad if it measures above 110 or under 90.... carbon comp resistors almost never measure lower resistance than their labeled value let alone be out of tolerance on the bottom end....so replace every resistor on the vertical board that measures above and outside of its tolerance rating. The ones below I sometimes ignore because I know they are usually in parallel with another part in circuit (which fools the meter*), but sometimes I'll unhook one lead and measure those again when I'm being thorough.
*2 equal Resistors in parallel form a single resistor of half the value... Resistors of unequal value form a new value equal to (R1 X R2)/(R1+R2)....there are formulas for more than 2 in parallel if you Google.
Resistors in series act like a single resistor with resistane that is the sum of all the resistors in series...these maths also apply to capacitors but parallel caps are the sum and series caps divide (ie it's backwards from resistors).
Always make sure all parts are good before deviating from the original design.
