Old 07-18-2020, 09:55 PM
BandDirector
Guest
Posts: n/a
If you have a clip lead(length of wire with alligator clips at each end), you could clip one end to the wire that contacts the Dag and the other to the chassis. If that makes no difference to the flicker then you can rule that connection out as a concern.
Did that a few steps back, didn't stop the flicker.
Old 07-18-2020, 09:59 PM
You see the silver rings with tabs pointing up and down on the back of the yoke?....Those are called centering rings and you adjust them by moving both tabs. The centering rings adjust both horizontal and vertical centering at the same time. When adjusting the vertical you have to juggle 4 controls: vertical hold(the user control near the tone knob), vertical linearity (inside chassis compartment), vertical height (near linearity), and centering....the goal is to get the most linear, centered image that fills the screen and doesn't roll...to do this you need a pattern of evenly spaced horizontal lines (which won't display even with the set out of adjustment as it is presently) preferably with some indication of the center of the video signal in the image. Then you adjust controls to center, even line spacing and fill screen on the TV (this may require going back and forth between each control repeatedly).
Boy I'm glad you explained that. I was about to go there but hadn't quite figured out a good way to make sense of the whole combobulation.
Old 07-19-2020, 10:43 AM
BandDirector
Guest
Posts: n/a
Question:
I have learned a good bit in a short time, especially since I had to do the full recap.
Before I start trying to really adjust and try to solve these continuing problems, what I could do is test the chassis components following the service guide. Use/learn the oscope, vtvm, create test pads with apropriate resistors, adjust the tuner to the proper mc readings, the picture and sound circuits, make sure the waves are correct, etc.
Would that potentially solve future problems? To service the set the way it would have been, would that insight add more to my knowledge base?
Old 07-19-2020, 12:21 PM
Originally Posted by BandDirector View Post
Question:
If and to an extent tuner alignment require expensive calibrated equipment and a very large amount of time and patience to learn compared to all other TV servicing and if you get it wrong it can be impossible to get it back...Wait a few restos before contemplating alignment.
The one exception to the above is tuner oscillator adjustment (which should center fine-tuning on channel)....your set could benefit from that and you can usually do it without significantly affecting alignment....there are almost as many different TV tuner designs as there are chassis so you need to read the manual carefully to find the correct procedure and adjustment points. Count the turns you make so if you were adjusting the wrong thing you can get it close to where it was.
Most schematics list voltages at the tube sockets anything more than 30% away from documented is likely an indication of fault. Note these voltages skew with the wall voltage in your house so if the B+ is 10% off so will be everything else...I often plug my sets into a variac and adjust the input voltage for the highest B+ rail derived from the power transformer/rectifier to be exactly what the schematic says so I don't have to factor a B+ skew into determining what the tolerance is in the socket measurements.
If measuring voltages on a live set work with one hand in your pocket and avoid getting shocked... Safety first.
You can sometimes find socket resistance charts which can also be helpful.
Scope work is often unnecessary once a set is as far along as yours is, but if you want to play around with a scope and learn how to see waveforms you can. I generally use my scope for adjusting H osc waveforms, looking for hum or other pronounced non-random noise, and when I suspect a waveform in a circuit is badly wrong and want to know exactly how it's wrong to gain insight into what is happening.
One thing I like to do when it isn't safe or practical to reach a test point with the set running is to take a couple of leads with small alligator clips on both ends and use those to hook the meter up with the set off then switch on the set. You can also get tube socket extenders but they are expensive and don't always match a needed test point.
If tubes test good and capacitors are new but a stage is performing badly the next thing I usually suspect is out of tolerance resistors...some circuits with large adjustment range like vertical I try to adjust first before worrying about resistors....the vertical could have been adjusted to compensate for a bad tube or leaking capacitor that you changed and now needs readjustment for good parts.
Old 07-19-2020, 05:58 PM
BandDirector
Guest
Posts: n/a
The vertical has a fold over at the bottom, fold is probably 4" on average, a black line appears near the center of the screen that should be the extreme bottom mask.
Old 07-19-2020, 09:22 PM
There's a big usually low voltage lytic on the cathode of the vertical output in most sets that can cause that...did you replace it?
Old 07-19-2020, 09:32 PM
BandDirector
Guest
Posts: n/a
I'd have to pull the chassis to look, but I don't remember a specific lytic for vertical. I can't recall which one is which, I'll look on the schematic. The lower 4 electro's are near the vertical line and height are near them, could be one of those that are 20 and 30 mfd at 50 volt. But those are new.
Old 07-19-2020, 09:41 PM
I see 2 pictures... looks like the vertical is running at half frequency.
Old 07-19-2020, 09:49 PM
BandDirector
Guest
Posts: n/a
How do you fix that? I've swapped vert osc and vert drive tubes and it isn't that.
Double check the values of the vertical stage film caps you changed and change any resistor that measures outside of its marked tolerance.
The cathode lytic in the vertical of most sets is a 25-100V 80-300uF lytic. Are you good enough at reading a schematic to differentiate the symbols for heater, cathode, grid, and plate? If so look at the vertical tube that drives the vertical output transformer and identify it's cathode and look for a lytic connected to the cathode.
The half frequency issue may be the only problem but if the foldover on the bottom persists after fixing the frequency issue check that lytic first.
Old 07-19-2020, 10:06 PM
Here's the vert circuit. Looks like the vert out cathode is direct to ground, so no cathode bypass cap(electrolytic). My money is on an incorrect value film cap too.
https://live.staticflickr.com/65535/...02e09742_b.jpg
Old 07-19-2020, 10:19 PM
BandDirector
Guest
Posts: n/a
It is certainly possible I made a mistake, I did have to go back and switch out a few caps because I would forget the 0 multiplier when reading values.
Old 07-19-2020, 10:33 PM
That's a pretty common thing. Are you using Sams 400 folder 4 for reference or something else?
Old 07-19-2020, 10:34 PM
BandDirector
Guest
Posts: n/a
I have an original field service guide, my local shop doesn't have that photofact. I do have a schematic for this chassis in the service manual.
Old 07-19-2020, 10:47 PM
That's probably even better because Sams changes the part location designation from the manufacture, although their photos are handy for locating components.
