Second the variac motion, bypass the time delay tube but keep in mind the relay may not pull in on the reduced voltage. The bigger problems I recall were with the CRT anode supply and weak HV transformer that was prone to shorting out, a real pest in the 545s as well.
A word of caution: use only a silver bearing solder on the porcelain terminal strips, I've damaged many in my time using standard 60/40 solder 109 |
There should be a small spool of silver solder bolted to the chassis somewhere if no one has stolen it. A lot of our scopes had a burn spot at the lower left corner of the graticule from using them to do X-Y plots of device safe area (I vs. V) and forgetting to turn down the beam. Last edited by old_tv_nut; 09-15-2021 at 11:28 AM. |
No that roll of solder is long gone. I don't think I've ever gotten a tek scope that still had it hiding away inside.
Regardless I keep a roll of silver solder buried for special occasions. |
