Old 04-24-2020, 05:21 PM
No problem. You should have the file in your email.
Hey tom I got it thanks again, but amazingly that SAMs is different Like the one I have but your SAMs has the right tube and comparing to the chassis I have here is clearly different. Different values on resistors as well as voltage differences even the way things are wired. There is a cap or 2 in this set that is not on either SAMs .I had recapped this set one cap at a time so I know I didn't put a cap in the wrong place. So I guess there is more then 2 SAMs for this set so at this point I'm not sure where to go from here. There are several 470k resistors that are in the verticle measuring .540m and .539m so I don't think that is so bad but if there were changes maybe these resistors in a given circuit cannot tolerate a rise in value. These resistors in both SAMs show 100k , clearly different. And the chassis didn't look like it was ever touched.
