Old 04-12-2020, 01:23 AM
ok back to this beast .. the votages after the 5u4 i get 295v when it should be 280v , 285v when it should be 270v , so its running a little high but not enough to knock things out of whack
vert out voltages are close its the vert mult that is off pin 6 should be 155v i get 92v , pin 7 should be -58v i get -37v
i will check the anode voltage to se what i get and post that.
Now the crt is a replacement , no number or make anywhere , is it possible the crt is not a proper replacement and the yoke needs to be changed ?
Also even if thats the case the vertical issue needs to be taken care of , you cant make a letter box image if you wanted to and as stated the 155v is 92v and the -58v is -37v and that could be a reason.
any suggestions ?
