That's a timeless and venerable piece of gear. Are you zeroing the meter for the ohms measurements?
I love the whole nature of this ordeal and I am hell-bent. Just need to stay calm. |
Tools I have:
CRT tester RCA Senior vtvm VoltOhmyst B/K solid state 2-channel oscilliscope B/K Dynascan 1070 (does not have test pattern) RCA Bias Supply HP VHF signal generator Projects: 1957 RCA KCS116C 21" Rangeaire AM/FM tube radio from 1964 - learning project radio I have been told to put the tv chassis components back together, and to find a compatible transformer. A smaller project was advised to first tackle how to restore a tube electronic, hence the Rangeaire. Problems: I do not know how to measure resistance in ohms, therefore it will be difficult identifying the resistors I removed from the tv chassis. I know how to callibrate the vtvm via the RCA manual. I know how to setup the oscilliscope via the B/K manual. I do not know how to measure a capacitor using my DMM, even assuming the cap is dead, I cannot pinpoint whether my reading is accurate. Therefore I cannot accurately place the old tv caps unless I can trust what is written on each one. They are clearly marked with volts and +- % for identification. The tv crt is rated good. The Rangeaire radio does work, a little low on volume but it does work. I can study and test the caps and resistors, tubes, and voltages to learn AC/DC measurements. Now what? |
In addition, you have to become familiar with ranges. For instance, a 680 ohm resistor is also known as a .68K resistor. A 820K resistor is a .82Meg, etc. Using known good resistors takes the guessing out. Quote:
If this is what you're referring to, then order a bunch of capacitors and learn the differences between pf, uf, and nf. NF was not used in the old days, but is more European than U.S. There are on-line conversion calculators so if your meter says a capacitor is reading 68nf, you can plug that into a converter and find it's also known as a .068uf. Most of these meters don't test for leakage as a good leakage tester must put the same voltage across the cap as it's rated for. For instance, a typical 0.05 400V cap may read .05 on a capacitor DMM tester, but become electrically leaky at 100V or more, well beyond the voltage a typical capacitor checker will test for. John |
Regarding the VoltOhmyst, you might have to re-zero it a few times until it warms up good.
