Couple of notes.
ARF has a thread where a TVS diode (basically a w way sense) is wired in parallel with the CRT heater and limits the voltage across the heater to it's designed value (more common cheap signal tubes take the hit instead). I'd highly recommend that option. Second I've found that goof off or rubbing alcohol will take sharpie off of chassis metal. Third enjoy your restoration.
