Old 11-29-2019, 01:12 PM
Originally Posted by Red Raster View Post
Thanks Zeno,
I will give that lead a try,
My set has a real good CRT also I do have a new 24LQ6 amongst my tube stock
and the horizontal efficiency coil is in great shape (offten they are burnt to crispy critters).
That chassis doesn't use a 24LQ6. It uses either a 31LQ6 or a 36MC6!
Old 11-29-2019, 06:16 PM
Not sure it doesnt Dj. 36MC6 used in later hybrids IIRC. There was a 14" & 19" all tube. IIRC the 14" used a plug in damper diode that went often & the 19" a tube. IIRC there was a differance in HV regs. also.. May explain the 24 or 31
filaments. One thing I know is ALL of them used those lousy 5GH8's. Always
have a sleeve ready when working on one !
Old 11-30-2019, 10:48 AM
The chassis you're thinking of are the CTC22,36, the earlier hybrids. The 22 used the damper diode, where the 36 used a 6 volt damper tube with the heater working off the transformer that furnished the heater voltage for the CRT. I also remember the HV regulator tube in the chassis.
The CTC51,53 used 450ma series tube and not as many 6GH8's. The IF strips and audio circuits are solid state.
Old 12-01-2019, 07:24 AM
ronl ronl is offline
Hi Red Raster.ill check rcc 134 manual and get back to you. RonL
Old 12-04-2019, 02:26 PM
Findm-Keepm's Avatar
Followin' the Rules...
CTC53 chassis schmatic can be found in Electronics-Technicican Dealer, September 1973 Issue, TekFax 1487:
https://americanradiohistory.com/Arc...an-1973-09.pdf
ALL RCA Chassis from 1964 to 1988ish are listed in the TekFax, and are available either in the ET-D magazines or the published collections Tekfax 104-116 available at ARH as well:
https://americanradiohistory.com/Rad...g_Magazine.htm <-left side
Brian
USN RET 22YRS (Avionics/Cal)
