Well that's a good starting point. Can those bar magnets be centered in the clamp doohickey so they are the same position on both sides? Not sure how much that will help. I need to sleep on this, not sure off hand why the brightness would need to be in a center position. There's also the possibility that someone has had that trap off the neck and it needs to be reversed front to back. Some traps have an arrow that indicates the end to be pointing forward.
I also can't seem to get the vertical and horizontal hold to lock in, and is it normal to be able to hear the vertical oscillator through the speaker on the TV?!
No you can't get the raster to lock unless there's a sync pulse from composite video signal being detected. Right now the horizontal and vertical oscillators are free running. You should have the ability to make the vertical roll up or down, just won't lock in. I'd say the vert oscillator sound is normal because you probably have the volume cranked with no audio signal to detect.
For anyone following here's the tuner portion of the Sams 101-5 schematic along with the voltage chart. https://live.staticflickr.com/65535/...38a31f87_b.jpg https://live.staticflickr.com/65535/...ec92c010_b.jpg Last edited by Kevin Kuehn; 11-07-2019 at 10:37 AM. |
Although I don't have any 6AG5 tubes so I subbed it out with a 6AK5 tube. I'm assuming I can take the voltage measurements through the top of the tuner's tube sockets with the tubes removed? |
OK so here's the measurements I got from the tube sockets on the tuner in the TV:
6AG5: What it should measure: Pin 1: -.2 VDC Pin 2: 0 V Pin 3: 6.3 VAC Pin 4: 0 V Pin 5: 145 VDC Pin 6: 130 VDC Pin 7: 0 V What I measured: Pin 1: -0.6 VDC Pin 2: 0 V Pin 3: 6.8 VAC Pin 4: 0 V Pin 5: 83.3 VDC Pin 6: 82.3 VDC Pin 7: 0 V 6J6: What it should measure: Pin 1: 110 VDC Pin 2: 83 VDC Pin 3: 0 V Pin 4: 6.3 VAC Pin 5: -2 VDC Pin 6: -6 VDC Pin 7: 0 V What I measured: Pin 1: 80 VDC pin 2: 74.5 VDC Pin 3: 0 V Pin 4: 6.8 VAC Pin 5: .2 VDC Pin 6: 0 V Pin 7: 0 V So it looks like some of my critical voltages for the tuner are a lower than they should be.
