If the arm is held to it's piviot with a C clip remove clip and arm clean piviot surfaces with lighter fluid or rubbing alcohol add some white lithium grease (ask for it at a hardware store) and reassemble. If the grease is becoming glue in one place it is probably bad everywhere it was used and you'll have to clean and decrease all greased surfaces.
The play eject cycle sounds like other problems are at play, but take it a problem at a time.
