The SO-259 aka UHF connector is what you want and IS different from a microphone connector.
The UHF connectors were typically found on pro and broadcast video gear into the early VCR era and is also very common on HAM radio and CB gear for the antenna connection. Mic connectors were found in audio mostly in the 30s-50s, and in test equipment like RF signal generators into the late 60s. Mic and UHF look similar in pictures but are different sized and not intercompatible... I've got enough gear to need both types of connectors and compare side by side.
