Old 09-04-2019, 01:22 PM
Have you checked that the AGC is working correctly? It almost strikes me as slight signal overload. Turning your signal generator output way down should verify.
Old 09-04-2019, 01:29 PM
The up and down wiggles on horizontal lines at upper left may be the yoke. (But I'm wondering why they aren't the same from top to bottom - maybe the pincushion circuit?)
The left and right wiggles at the top are probably just the horizontal AFC. (Reacting to non-standard sync from your cross-hatch generator? It would be interesting to check if you get the same result with a DVD source.)
Old 09-04-2019, 04:17 PM
I experience that very issue with this Heathkit IO-101. Drove me about nuts trying to figure out the issue.
http://videokarma.org/showthread.php?t=268858
Old 09-04-2019, 05:23 PM
trinescope trinescope is offline
The crosshatch is actually from a DVD that I made with a few test patterns on it. Some time later on I'll get a schematic for this and see if there are problems with the sweep waveforms. I did have to put in a new 36KD6 since the one that was in the set when I got it was broken.
Erich Loepke
Old 09-20-2019, 08:19 PM
I finally found the problem, but don't have a really good fix at this time. The top core of the pincushion saturable reactor had fallen off and is lost. It was simply glued on when it was made. I did a "fix" from a few small ferrite cores glued together and then glued to the saturable reactor. The pincushion control has some effect now, just not enough. The problem is these transformers use a special core material that saturates easier than the ferrite I used, that's why I have only partial control at this time.
Erich Loepke
