Old 08-10-2019, 05:23 PM
decojoe67's Avatar
1931 Brunswick 12A mini console
I just acquired this from a friend. The set is so small it can be described as a large tombstone radio on legs! It may be hard to believe, but the set is entirely original. I spent about 4 hours refreshing the cabinet. The original floral grill cloth is very delicate and I haven't seen another example with it still in place. It's unusual in that the small center knob is on/off/volume and pulls out in three positions. With each position, the dial lights in three different colors, and tones. The large tuning dial requires a gently pressing inwards to activate. The rather odd chassis is difficult to repair and eventually I will have that done. I just get a whisper out of it right now. I like it just as a 1930's piece of art!
Old 08-11-2019, 08:17 PM
That's a neat little radio! Its interesting that they used one knob to control everything on this radio!
Old 08-11-2019, 09:08 PM
Purty l'il feller ! Methinks Ya done Good !
Old 08-11-2019, 10:06 PM
I think it's noteworthy that Brunswick is one of the very few companies that built radios in that era and is still around, and not just in name. I love gimmicks like color changing.
Old 08-12-2019, 05:54 AM
Titan1a Titan1a is offline
A real bummer to work on. It's tight in there.
Rick (Sparks) Ethridge
Old 08-12-2019, 08:40 AM
decojoe67's Avatar
Thanks guys, and yes, I've heard about these chassis'. It's the reason I've stayed away from early AC sets. One local repairman I know passed on working on it. I'm going to keep trying, but I have a feeling it might just stay as a static display.
Old 08-16-2019, 01:42 AM
decojoe67's Avatar
***Update - A long time friend repairman checked the chassis out. After quite a while trying to figure out the odd chassis he pinned the problem to an open resistor and choke. With the repair made, the set came to life and plays as new. It's super sensitive and gets stations all over the dial. I can't believe this old chassis, which likely hasn't been repaired since the '40's is back playing once again without having to dig into that crazy chassis! Amazing how well built things were back then to be alive once again after probably 70 or so years.
Old 08-16-2019, 12:47 PM
Your radio situation is kind of like the situation with my old Westinghouse WR-10 Tombstone radio I recently acquired. The original cabinet on it was shot beyond repair but the chassis although a little rusty was still clean inside and had never been repaired in its entire history as it still even had its original cloth cord intact yet on the chassis.
Anyways I cleaned up the rust on the chassis and the tubes (which were absolutely filthy), and went to put the radio back together to test it, and it wouldn't power on, did some testing and it turned out the original cord had an open somewhere on the neutral side, so I wired on a temporary cord for testing purposes and the radio came to life and it was working perfectly with its original Dry Electrolytic Power Supply caps still in place.
The interesting thing is is that my radio I got going had previously been sitting in an old Farmhouse that the roof to it had collapsed 20 years ago which is why the cabinet was shot and chassis was somewhat rusty but considering the conditions that the radio was stored in for the past 20 years the radio still worked with not much work to get it going.
Old 08-16-2019, 05:13 PM
decojoe67's Avatar
Great story! I've actually heard many of them in all my years in the hobby. Many of these early sets were so overbuilt that they proved to be even better than the engineers likely ever anticipated! I have a '28 Radiola 60 that is still working fine with no signs of any repairs made.
Old 08-16-2019, 07:30 PM
That's amazing!
A friend of mine has an old Radiola Cabinet minus the guts but the cabinet is still in good shape yet.
Old 08-16-2019, 11:06 PM
decojoe67's Avatar
That's amazing!
It's actually all not that uncommon with early AC sets from the late '20's into the early '30's. You either get lucky and it plays as-is or you have to excavate the tar filled cans which contain the caps. A tedious, messy job. Early AC Radiola's are the most likely to play as-is. They were so well built. The thing is that they're VERY common and have moderate value. An empty cabinet is not worth a whole lot, but definitely has value. A person who has the set with a bad cabinet will surely be happy to find it!
Old 08-17-2019, 03:19 AM
Well sadly enough the cabinet is just being used for storage by my friend and unfortunately the whole front fascade where the guts would of went including the speaker grille area were all cut out of the cabinet to make it so that it could be used as a storage cabinet, so all that's left of the cabinet's fascade is the doors that covered the radio's tuning dial and speaker.
Old 08-17-2019, 06:38 AM
decojoe67's Avatar
I see. Well, at least it was repurposed for something useful.
Old 08-17-2019, 07:19 PM
Well I actually tried to look up the model of Radiola it would of been based on the cabinet shape and everything and I couldn't find anything that matched, which is weird.
Old 08-18-2019, 12:09 AM
decojoe67's Avatar
I have the big book on the history of Radiola, which is great, and found their are many, many models produced in the '20's. If I had a pic I could help you.
