Old 07-24-2019, 09:43 PM
I've done 3 or 4 of the RCA type using a heat gun, with no drama. In another case I wanted to save the faceplate from a dud Philco-built tube with the RCA type PVA. At the time I had access to some infrared lights used to dry paint; the same bulbs as a "french fry warmer". I aimed these at the face for perhaps 30 minutes and the plate popped off nicely...but the aired-down crt developed a large crack.
On another aired-down tube, where I wanted to save the plate, I used a propane torch and that worked very well. I believe I'd be daring enough to try it on a "live" tube. It seemed very similar to the heat gun (I no longer have one of those).
I learned the water method years ago by accident after pulling a 21FJP22 out of the woods (where I'd left it years earlier, unaware that it could ever be of any use with a serious cataract). The only thing holding the faceplate on was what remained of the tape. Based on that I was able to do one RCA after soaking and using wedges for a couple weeks. (I've found I don't really need wedges with heat.) I have tried a Zenith and a Zenith-type from a Motorola (I forget who made that tube) and neither was successful. In both cases I cracked the plate in trying to remove it.
If there is a next time with an RCA, I think I'll start with the sun. For a Zenith I'd look for some of the wire used to cut out windshields.
