Old 07-14-2019, 10:47 AM
I don't see anything I would call a ghost. A little misconvergence, maybe some spot blooming on the bright lines, and what appears to be some cross-color (the ragged-looking color mostly to the left of the vertical lines) that should go away when you turn the color all the way down.
Don't obsess over little things until the major things are fixed. It's easy to get hypercritical and expect an analog set to look like a computer monitor. It won't. It is normally watched from ten feet away, so the technician's view with nose pressed against the glass will just drive you crazy trying to reach perfection.
https://imgur.com/fWo0QBs
this is what i mean
this shadow should not be there
i can find a good image someplace, but will take time
edit...
digital capture of source
https://imgur.com/CRUNIvo
this is what I mean
