Old 04-23-2019, 10:43 AM
Shango just started on a similar one.
https://www.youtube.com/watch?v=hqH8dZuUuoQ
If yours is solid state it will need every small electrolytic in the
hoz & vert & every control cleaned. They were that way even at 5 yrs
old. They will work good then.
Old 04-23-2019, 06:13 PM
liammc00's Avatar
liammc00 liammc00 is offline
real TVs have a CRT
It looks to be all tubes and no transistors.
Old 08-21-2021, 08:21 PM
liammc00's Avatar
real TVs have a CRT
I recently got around to working on this old sears tv and have made some good progress. I have recaped the tv. The tv now makes a pretty watchable picture but the sound is still not working right. The sound is very staticy like it's tuneing in a very weak signal.
I need to test the following tubes 6gh8 detector amp-vert mult and 6hz6 audio detector. My tube tester is a knight 600B and I do have the books(manuals). I couldn't find these tubes listed in the books I have. So I'm stuck at the moment and if any one knows how I can tests these tubes in my tube tester it would be much appreciated.
Old 08-22-2021, 10:19 AM
For the tester get a tube substitution guide & see if any listed subs
are there & test it that way. May not be perfect but it should show
up a really bad tube.
https://www.ebay.com/itm/25507945015...QAAOSw-Xdg90sh
Audio tips
A HISS like a weak FM station is the audio IF stage.
A BUZZ or ticking is the audio detector stage.
The buzz can be effected by the ACG, fine tuning & your source.
Old 08-22-2021, 01:46 PM
liammc00's Avatar
real TVs have a CRT
Audio tips
I bought the book and I will have it by the end of the month. I think the 6gh8(sound if amp-vert mult) because the vertical was shrunk but I was able to adjust it to fill the screen. Thaks for the help.
Old 08-22-2021, 03:39 PM
6GH8's & their cousins #GH8 were probably the worst tube
ever built. Some RCA color sets used 5 of them & after a few
yrs they would be weak or leaky. Always suspect them !
Another tube checker tip. The first number of a tube is the filament
voltage. A 6GH8 is the same as a 5GH8 or a 4GH8. Just the filament
needs to be set to the proper voltage to test. You can also smoke out
a bad tube by turning up the filament one notch ( say from 6-7volts) this
can find leaky tubes that act up after the set runs a while & gets REAL hot
inside.
BTW You may be tempted to adjust the transformers in the audio. DOO NOT do
it unless you take precautions ! AND dont change disc caps. They almost
never go bad !
Old 08-23-2021, 12:08 PM
liammc00's Avatar
real TVs have a CRT
inside.
never go bad !
The only tube that looks like it was replaced was the damper tube. The rest look to be original to the set.
Old 09-27-2022, 05:22 PM
DavGoodlin's Avatar
Motorola Minion
We saw alot of "little" Sears stuff come in the shops I worked in here in eastern PA over 40 years ago. Still, we knew they were as simple as a GE S-2 LOFL, and people wanted them fixed. Also, I knew they were Japanese unless 528/529 prefix, with tubes not stocked for any set over 10 years old.
If the elder-boss wasn't in to turn them away for that reason, I would write them up and quietly source that 4DK6 (or whatever) at home, then say "hey look what I found?" and if the boss was in that day, he'd say it's a "bastard" number he did not remember ordering.
The bad caps responded to freeze spray back then, dirty pots responded to Lube a trol.
-Dave G
