Curtis Mathes 4224
I am needing help finding any info and a schematic for this tv. I did not find a chassis number, but there is a lot of dust and some corrosion. I am hoping someone recognizes the tv.
Here are some photos: https://photos.app.goo.gl/VWgJvQN8HxAZpdXH6 The CRT is not busted and the filament does have continuity. I am going to put the base back on soon and test the CRT. Thank you! |
You really need to find the model number or chassis number to work on this. You need a CRT tester to test the CRT because the chassis is probably not working well enough.
EDITED: Sorry I mis-read your post. I didn't find any Curtis Mathes 4224 at the SAM site. Last edited by Notimetolooz; 01-24-2019 at 12:57 PM. |
I do have a CRT tester. That was my plan for testing the CRT. The model number on the TV tag is 4224, the issue is that the corrosion has covered/removed the chassis number. I was hoping to figure out which sams would have this tv if someone could recognize it.
First get some date codes off some ORIGINAL major parts.
Then find SAMS for similar models about 6 mo to a year later. If you have access to a collection thats great. If not someone else may or you may find them on the internet. You will find a similar manual most the time. 73 Zeno ![]() LFOD ! |
If it is 62 or older I can pull folders and take pictures of the tube charts to help ID it...
They were built rather well then. |
I really do appreciate all of the input and help so far!
The original Curtis Mathes tubes have date codes of 1959.
Sams Index says: 1959: Folder: 468 set 1 1959: Folder: 465 set 6 |
Sams shows a 4200 series, folder 506. |
I do really appreciate all of the help!
I have ordered two different Sams. The first sams covers chassis models: 1121, 2121, 3121A, 5521A These models use a 21CBP4A picture tube. Which is what mine has. The second Sams covers chassis models: 7323, 9323 These models use a 23CP4 picture tube. Both of the photos on the front of the Sams shows only 5 knobs on the front whereas mine has 7, but I think these two Sams will get me started. |
For anyone who is interested I thought I would post an update. The tv is recapped and working! Someone had tweak all the controls so I did a rough alignment.
Sorry for the terrible photos. This will make a great workshop tv. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SAMSUNG-SM-G891A using Tapatalk |
Interesting early Mathes TV set. They didn't make too many of these sets before the change to Curtis Mathes. The Mathes company made radio sets, and radio/phonograph consoles before they made a TV set. A rare bird.
Mathes began by making the Mathes Cooler, a well known electric fan in a wooden case with louvers. From there, Mathes branched out to making Radio sets, then HiFi console radio/phonograph combinations, and then televisions. And a little bit later, renamed the company to Curtis Mathes. Which is what most people know them best as.
Awesome TV and the pic looks great!
Now put those bumblebees and black beauties on ebay |
I recently got a box of channel knobs with a few of those CM channel selector knobs in it, and now I know what they go to.
