1969 Magnavox remote color set
I collected this set last week from an estate sale in Farmington Hills, MI for only $40. It has some issues, a dim picture despite the CRT testing brand new, very poor convergence, probably caused by that rectifier block on the convergence board. The remote does work, but it takes a special 9V battery that costs $22, so I just clip leaded a regular 9V to the terminals.
try a new video out tube, weaker they get the darker the pic becomes. Or just check the CRT pin voltages, esp the cathode and G1
Isn't Farmington Hills, MI where all the wealthy people are? Anyway to-each-his-own! That 9 volt battery was never cheap, but $22.00. You should be able to make up your own with Dollar store coin cells.
Yes, the video output gain at max contrast is limited by the video output tube gain, so you will even see differences between "good" video output tubes.
Looks like it's in good condition, please post some pics when finished.
Did you clean the service switch and work it thru a few cycles?
If I remember right it's full of 6GH8s. One of the causes in those early Magnavox models, was a 6GH8 that is used as a blanker. Sets near the video output tube. When that tube gets weak the picture gets dark and poor contrast.
Lets not turn this into another bash French provincial thread !
In the right house they look stunning. In the wrong house they make you wanna puke ! Walter has a great point on the blanker tube. Its probably the most disrespected tube in a set. I have found more bad ones than video outs often causing subtle vid problems. Many seem to just pretend it isnt there....... 73 Zeno ![]() LFOD ! |
Seconded. Shop I worked at in Oak Ridge, as a junior technician. First thing with Magnavox color sets with a weak picture was replace the 6GH8 Blanker if used. Usually an overlooked failure item. See more of these bad than video outs myself.
I changed damn few video outs. First video amps & blankers went far more often. Admirals with a 6EW6 1st Vid could be changed every year & make a huge difference in detail in a pix. 73 Zeno ![]() LFOD ! |
Looks like the manufacturer went for actual sliding doors on this unit. I'd be surprised if the look was faked.
Maggie did several ones with real doors...There were two things they excelled in during the tube era audio and cabinets.
Yes, real tambour doors.I had a similar one in which the fabric backing the doors had stretched with age and would bunch up and bind when opening the doors. I didn't take the trouble to fix it before passing it on to someone else. I'm not a cabinet maker. I think it would require cutting all the wood pieces off the fabric and gluing them tightly side-by-side to new fabric.
Agreed highly. Audio and Cabinetry were strong Magnavox points, I'd say into 1967-1968, their console Stereos were the best sounding in their field. And Magnavox cabinet work was also top notch (they were made in Greenville, TN, and a top employer in Eastern Tennessee). All Magnavox TV sets were built in Greenville, TN in that era into the middle 1970's. And Magnavox phono cartridges (Electro-Voice, by the way, were made in Newport, TN)
